I saw this in Enscape website but couldn’t find it in Enscape on my computer?
The sun position in Revit is controlled in Revit Location and Render Settings (Location, Orientation, Time of Day and Date). You can set the sun position in Enscape and save it back to Revit. Be sure to uncheck these options. Revit will read the sun position, but when recalling the view, Revit will determine the sun position. This article might help if you’re trying to create solar studies.
https://www.linkedin.com/pulse/creating-solar-studies-revit-enscape-phil-read/
Set the sun position and save the view to Revit. Subsequently, if you want to update the sun position, you’ll have to change the sun position in Revit. Presently there’s no way to update the Sun position from Enscape back to an existing view in Revit.
Hey, sun position in enscape is in rendered view. 3rd icon from top left(Like Binocular). Hope it helps
What version of Enscape are you using? The ability to set the sun position in the enscape view settings is fairly new, perhaps you are using an older Enscape version?
