When it did not mess up (from my own experience of course)
There is no Windows Based OS on this Amazon Service. Sorry there is finally, not on the front page but on the EC2 one.
You are probably using Maya and not max.
What Plan are you using?
Can you describe better how you set it up?
What are the 750H free for? 750H of rendering services free of charge? I have some doubt!
Currently, as we speak, I am trying Render Rocket. So far, it uploaded all my assets really fast, and they give you unlimited test renders. My greatest fear is rendering out a still, just to see a mistake that I have to correct, and pay to re-render. If the price is right, this might be my chosen way to render large images. I’ll let you know…
I just got my test, and it worked great! It took 17.56 core hours, so I’ll have to find out what that’ll cost in real money.
I just read that they charge $0.70 per core per hour, so the render would cost me $12
good feedback, thanks for sharing (RE: Render Rocket.)
Heya
1st ITS NOT RENDER SERVICE. Its computer RENTAL. You rent 1 computer. You set up windows and all. You save the image of that on ec2. You rent extra 10-20 pcs as many as you want and use saved image as window. So you have all settings and so on.
You pick computer with the power cpu/ram and then you rent them.
There is window, linux, red, and more. - attached image…
750h of ec2 instance is basically a basic 1-2 core 600mb ram computer that you can rent to set up windows program and more for FREE. For 1 year.
I will eventually do a full on tutorial how to set it up and abuse…
That will be very useful.
Dariusz, you’ve just become my new best friend ![]()
Can this sort of thing be used for Activeshade ? I saw this for iRay on YouTube https://www.youtube.com/watch?v=Hf23h9T6p6E&feature=youtu.behttp:// (this one is for iRay).
But I’m really keen to start getting this sort of thing into my workflow.
You might also want to look into the Google cloud - it seems to be better in some ways (plus, it supports per-minute billing rather than per-hour).
You can use a cloud for ActiveShade and I’ve done this a few times, but usually the network speed ruins the experience (at least, from our office in Bulgaria).
How does EC2 work in terms of the vray license? I need a node license for every instance?
Yes, you will need one Render Node license for each virtual machine (instance) used for rendering.
do you have any info on Google’s cloud computing. I tried Amazon’s, a private service, and I want to try Google. Or, is it the same as the VMWare cloud service (DAAS)?[quote=“ValeroStudio, post:5, topic:44729, username:ValeroStudio”]
[/quote]
There’s more info here:
perfect, thanks![quote=“Guest, post:3, topic:44874”]
[/quote]
So how complex was the scene, i.e. how long did it take on your own system?
I set up an instance, but that is as far as I got. I am waiting for Google to enter the DAAS space. But, like everything Google, it’s less expensive.
104GB RAM, 16 cores, 24/7 = Monthly total: $663.08
Glorybound, maybe you can answer a simple (stupid) question…do I have to install windows 7, 3dsMax, Vray, etc., on the instance - I don’t quite get how that works on a server?
not stupid at all. If it is like Amazon, which I am assuming it is, you install just like normal. You create images (everything installed like you like it) and when you call up an instance, you pick that image. You can work on one instance and call up more when you go to render. But, having said that, you’ll need a VRay license for every machine (brilliant move on Chaos Group).[quote=“tryharder, post:12, topic:44855, username:tryharder”]
[/quote]
