Hey guys,
Planning to change my monitor. I am going to use only for 3d and design purpose. (No gaming)
Already using Apple Cinema Displays. I am very happy with them as they offer great genuine colors with wide gamma range but they are pretty old and having big proplems with the pins on adapter.
I purchased the Benq 32" PD3200U a few months ago and like it very much. It’s a 4K monitor so more expensive then the 2K PD3200Q. I would think you would want the 4K if getting a 32" monitor but individual needs and etc of course vary.
My next choice was a similar spec Dell. I cost more but had Adobe RGB color display mode. The Benq does not have that capability, but working in the Adobe RGB color space is a bit of a rabbit hole with gotchas and “it’s not a perfect world” type issues. So.. decided I did not need to display the Adobe RGB color space and saved some coin.
Hi, since one year I am using Benq BL 3201PT “designer” monitor and I love it! It is UHD 32 inches 100% sRGB and around 75% adobe RGB if I remember well so colors are very accurate. The screen coating is like semi matte. It has the external corder controller to quickly switch between screen modes - CAD mode for modeling is pretty neat and I also use lowBlue light mode a lot. It is able to automatically detect if you are in front of it can turn itself on and off. Btw I was lucky enough to get the second one in pretty much brand new condition for just 400€ which is not much considering the 1000€ release price. I believe the newer model is cheaper and costs about 750€ on Amazon.
I was using two Dell 20" FP monitors until this summer when I switched to the 32" 4K monitor. There is definitely a difference in how you will arrange your screen workspace - tool pallets, frame buffer, etc. I’m getting used to that and it is ok for me so far. In my experience, the menus and dialogs on modern software, like 3ds MAX and Photoshop, Firefox do not become too small. I think these programs have built in compatibility with newer 4K monitors. With older less current programs that is a minor issue.
I like having just one monitor. When I had two, trying to calibrate both to appear exactly the same never worked for me. I’m trying to reduce the number of devices I have plugged in general
I agree with Mark, big uhd screen gives you a lot of space to play around with your workspace.For me it goes like this:
Pros:
• 4x times more pixels on the screen can give you that extra precision when modeling or pixel perfect post
• Working inside a huge viewport is so neat! It might sound funny but it really helps you to immerse yourself in the project - giving the feeling of control
• From every day examples, I am able to scale my framebuffer/ maya hypershade (material editor) / UV editor - etc etc. to almost full hd size and place it one of the viewports.
• This size monitor can easily substitute your TV
Cons:
•Requires a bit more power - I have mine plugged to laptop with gtx 1060 and it can sometimes struggle to keep the viewport smooth
• Can be really heavy, my Benq weights 17kg (!) so if you ever want to mount it on the wall it is not easy to find strong a enough arm
•Scaling…not a huge issue anymore but you can still find yourself with your nose inside the screen if an app doesn’t scale properly. I found Substance Painter to be the worst but that was 6 months ago so maybe they fixed it.
•Windows 10 scaling is still not ideal, I found 150% scaling to be alright but some stuff still looks blurry.
Pfff, peanuts! My old 24 inch Sony Trinitron grade A CRT (circa 2000) weighed over 100 lbs… Forget about finding a strong enough arm, you needed a strong enough desk
Hahaha! What a heavy cow it was for an 24 inch monitor, damn! But c’mon, 17kg for an LCD is still pretty heavy considering that the same size Dell weights like 6kg :-P:-P
Thanks for the share.
This looks cool.
I am using 3 monitors at the moment which makes 1200 x 3x1920 . while 3ds max is on one window, I put all my 3ds max setting windows etc on one side screen and I put the ref images and chrome, spotify, bridge etc on the other side screen.
But seeing your screen made me feel one 4k is better than 3 monitors!
I am using a 38" Dell and two older 24" screen to the left and right vertically. In the middle max is open, which is very nice to use on such a wide display. The left screen has the slate material editor open and the right shows folders and internet.
All this is on a 3-arm monitor holder, which creates a lot cleaner desk.
I like to be able to switch between to attached computers easily and using the same mouse and keyboard with the 38" dell. This is nice if another computer is rendering.
Nice setup @bildform !
I would like to add my another w cents regarding big 32 inches screen. Recently we acquired 32 inch 4k AsusProArt monitor and my collegue is using it since one week and he complains about its size. By having to constantly moving his head due to its size his neck is painful. I I don’t have this problem with mine monitor at home but it is definitely something to consider before getting one.
