white balance from camera
Hi everyone,
Am I the only experiencing problems with the white balance from the camera?
either is set on d65 or neutral, colours won’t change, they look the same
Lorenzo
Are we talking about the V-Ray Physical Camera? There’s a variety of White Balance presets from which to choose. Do you see only those two? There’s no difference because Neutral and D65 are similar (5000-6500K).
Otherwise, have you tried using the Auto-White Balance option (Render Setup> V-Ray> Camera) and transferring the value to the camera?
Hi Aleksandar,
you are right, neutral and d65 are very subtle in difference.
might be my fault, I used to use vray for cinema 4d, 1.9 verison, so maaaaaany years ago, and d65 had a stronger blue dominant, that’ why was looking weird for me.
My bad, sorry.
Lorenzo
