I have random issues with the White Balance parameter when I’m using takes. It’s not something new but since it’s random, I’ve always avoided to report it. Now I have 15 golden renders with f***** up colors that I’ll have to fix in post.
I’m working on a project right now so I can’t do a proper bug report but as you can see on the current rendering, every WB value in the scene is 4000K, and yet the value used by Corona is 6500K. It’s the only setting that is wrong and doesn’t follow the Camera Tag settings.
I’ve checked every image before rendering the takes, fixing incorrect WB values. Yet when the final rendering starts, the WB is using the default value, even if a custom value is used in the scene and the override visible in the Takes Manager. I guess it’s not a C4D issue since the other settings work as expected.
Also the WB parameter is displayed like this in the Takes Manager after it’s overridden in the Camera Tag. It doesn’t feel right :
Cinema 4D 2024.4.0 + Corona 11HF2
