White dots in animation
Hi. White dots appear in the animation. I couldn’t find out why. I would be glad if you help.
you can see attached video file
the problem is solved if we disable the “visible in reflections and refractions” in the sun.
Would be great to see an actual rendering showing those white dots :smiley:
it’s in small attached video file :wink:
I am also did’t notice at first
Which version of Corona are you using? Secondly, would you also be able to send over your scene?
Instructions on how to do this are in my signiture.
Rowan
Hi zeybek,
Alternatively have you tried using highlight clamping in your System/Image filter rollout? Preferably use values of 1.1 - 2.0(above 2 your reflectivity will be greatly suppressed), do keep reflections of sun when using the HClamping.
We could also have a look at your scene for some further optimization/suggestions.
