White edge lines on ceilings issue
Hi all,
Been having a few issues with a weired white lines on the edges, any tips?
Current precview is with a standard corona material ovveride, no edge bump, no sharpness .. In System opts I also used the Highlight camping a few values from 20 to 100 .. still nothing:(
Any suggestions would be a plus,
Cheers,
Most likely your walls are made from one sided polygons. You need to add some thickness to it - shell modifier should do the job.
Yes!!
That sort it out:)
many thanks
You’re welcome!
