White glass with bmp env behind, how to solve this?
Hi guys, as topic title, when i put my glasses mat to my windows with a jpg as environment i get solid white color, why? It is a bug or what else?
Thx :slight_smile:
you’ll need to show us your settings dude .. on a side note have you got your glass reflecting on the back side ?
thx natty for your reply :slight_smile:
glass mat is pretty simple, white color for diffuse/reflec/refract with 0,01 fog and fresnel refl checked :wink: IOR refl 1,6 and IOR refr 1,01
EDIT: i also just tried with default egz vrayglas but without luck
white for the Reflection ? … thats 100% reflection dude.
You are right natty, but with “fresnel reflection” checked it would be trasparent though :wink:
You can try to make a box with glass mat ahead a teapot and to put a jpg env, try to render :wink:
A couple of render on what i’m talking about:
without glass mesh:
and with glass mesh unhidden and pretty defalut glass mat:
Until today I ever used the same glass mat to do my window, so a) something has changed (and i don’t know) b) it’s a bug
mmm … i see what your saying .. can you reproduce it in a simple scene and send it to me ?
I just tried with a simple scene and glass works fine…
It looks like you have ‘Override Max Reflection / Refraction’ checked under VRay’s environment tab. Just a thought…
Dan
DanielBrew, thanks!!! :wink:
I unchecked refl/refr in vray override and glass now works :slight_smile:
… but now i would like to know if this is a bug or it works like it wolud be :?
thats exactly how its supposed to work. stick your texture in the override slot and should be fine as well.
It’s not a bug, that’s the way it’s meant to work I think.
Ok :slight_smile:
Thx you guys :slight_smile:
