White kitchen
Hi guys !
I’d like to share my last personal work.
Done with Corona 1.4, photoshop and camera raw
I have also tried to play with arionFx, but I think I did somthing wrong. Because I have an error when I open my EXR (32bit/full float) in arion.
So, if anybody can explain the good workflow, that will be nice ! Thanks
That means that there’s no single pixel with greater than 1.0 value in your exr. This can be normal if there’s no directly visible bright light sources or highlights in image. Try to render something with bright lights visible and load it in aFX. If you still get an warning message, that means you’re saving exr in wrong way.
When you save from Corona, try to keep highlights compress to default = 1; and also the contrast to default=1; If you already didn’t do it.
