White points
hello to all,
I have a small concerns with a materials, I explain: on the joined picture, with the new vray (version 1.09.03f) my materials inox is done me white points all over… The problem is it known? With old version of vray, no problem
Thank-you for your assistance
A+
Vince
your not using an old irradiance map are you?
Hello Da_elf,
no, i don’t use old irradiance.
if i change my reflect interpolation, the size of the with points change (-3,-1 = smaller points then -3,-2) :shock:
very strange for me…
best regard
Vince
your using interpolated glossies? how many samples are you using 50?
no, only 20
i could be wrong but thats a little low when dealing with interpolated glossies. thats the setting i use when doing normal glossies
ok, thanks
i try with 50 and i post result
thanks for your help
Vince
i have trying with 50 and the problem is always present…
i don’t understand :cry:
Can you post a screenshot of your settings?
Regards,
Nenad
try without interpolation and see if the problem is still there. Then you know if the problem is interpolation or not.
