white reflection error
suddenly my beige plastic material has white - only -white - texture and reflection. Even when I turn reflection off, this is the case. When I change ISO, F-Stop and other values nothing changes the white color of the chair. Is it my fault or a bug?
OK seems my fault, but the ground was so okay and i thought the beige was an error…
Care to share with others what the solution was? They may experience something similar and could benefit. Was this a lighting issue? Seems to be a great difference between the 2 images.
It was a camera issue, the ISO was to much. It was my fault, I overlooked the ISO. I had to make the ground to a brighter grey and now everything is ok.
What I learned: Alway have a contrast when set up lighting, a bright material (chair) and a darker (ground) is ideal to set the correct light ((((:
