I am trying to figure it out but have some problems with it. I cant get rid off these white splotches on the floor. I know this topic was talked about many times before but somehow I cant find a solution to it. Any ideas ?
Rec Lights in the ceiling double sided invisible
Most of Materials simple white
What are your Primary/Secondary rays settings? Keep in mind it is advised to use Brute Force/Light Cache for optimal result.
You can send us a scene to support@chaosgroup.com so we can investigate further. Thanks!
Why do you have caustics on? Turn them off, the splotches you see are most probably caused by caustics…
First of all Set the Sample size in light cache options to 0.01.
Tun off ambient occlusion
This is most probably the issue.
I also don’t see any reason for Caustic calculations in this scene.
