hi, i have problems with this rendering for an interactive panorama. it seems that i have the splotches mostly in the floor. i rose the subdiv. for refl. of the floor mat. from 16 to 64 but out of an huge rose of rendertime the output was nearly the same.
3ds max cam
direct light - mult 2,0
hdri in vrayenvironment - overall mult 2,0
exponential color mapping
Have you tried some general troubleshooting yet? Like uncheck reflections in the global rollout? Does it go away? Use a grey override, and see if it goes away.
thanks for your replies,
unfortunately none of them solved the problem. there`s no standard material in the scene, caustics are disabled, clamp output checked,…
more suggestions?
I had some scene s where the white splotches appeared due to a raytrace in a material from the scene. When i disabled this setting, all splotches where gone.
It s worth trying
I have similar spolotches when my physical camera parameters are not correct.
I think that your f-number and shutter speed are too low. Try to set higher values
like 8 for f-number and shutter speed 200 and set Dark multiplier to 3 at
V-Ray Color mapping. It works for me.
still no solution, but i am on the way…
the splotches must be caused by an material, cause when i use an override mat. the splotches are gone. the suggested causes - blurry refl floor material and selfillu. material in the lamps are not the originators as i excluded the objects with them on from the override mat. and everything was fine.
@gerard: also have your suspicion but havent found the material yet…
@vlado: i have only one direct light in the scene, no vray sun. thanks again for the opportunity to send you the file. until now i haven´t managed to send one as the filesizes are too big for my emailaccount. i am looking for a filesharing possibility to bring the files over…
found it. the scene setup before trying to render the image for the 360° panorama was with vraysun/sky and phys.cam. i had to make a new setup with 3ds max camera as i needed the sperical camera type. by doing this i reduced all vraylightmaterials in the scene but forgot one in a ceiling lamp…
hmm, I’m having the problem but no lights in the scene, only Vray materials, using clamp output with sub-pixel mapping. so I can’t really figure it out.
The object that it’s noticeable in stops having problems when I change it to be not visible in reflections/refractions.
I’m kinda lost on this one. I changed it’s material to a standard VrayMtl also and it still reflects super spotty.
