Did another test at home pc using adaptivity for progressive rendering settings that keymaster recommended, I can see that there is a good improvement difference although render time goes up slightly
Edit:
Wow PT+HD cleared up even faster in the same amount of passes
Why highlight compression installed about 20, and many exp correction? Did you can set up the scene so as to avoid large values of adjustment? I mean correct lights settings denoise the scene more quickly.
