Why are the wall cut edges shining in Enscape view?
I got a really odd problem. All the cut edges of the walls (doors, windows, etc.) from Revit model started shining in Enscape. Also the white objects like sinks got luminescence. I think it happened when I added some lamps with luminescence settings to my model. Other object materials don’t have any luminescence in the settings and the walls material is wood. Does anyone know what it has to do with?
Thank You
Check that the wall material has self illumination or you’ve use the paint tool to apply material that has self illumination.
