It is not a problem of EV value because if I do the active shade the image is fine, but when I send the render of the viewport the render is white. In the scene in addition to the object to be rendered there is only the sun which is set to obtain the right shadows.
Since activeshade uses Arnold, the results from that can’t be compared to what Corona will create - meaning it could indeed be the EV
Try adjusting the exposure in the VFB.
Can you send a scene where this is happening?
Sending the scene as requested is the best next step
See links in signature to find the private uploader.
