Adding 4D people to an animation and when I do a liveLink, they don’t render. Why? Since the Anima people come in super red and contrasted, I need to adjust them.
If Anima 4d people are completely missing from the Vantage render/live-link, then probably you need to activate the Enable Object render State from the Vantage Toolbar Settings.
But for any huge color differences from the VFB and Vantage, please share a screenshot,
Awesome… makes my life easier. Now I can see my adjustsments.
No. Srgb and gamma 2.2. Srgb set in Vantage.
Vincent Jaramillo
Arch Visualization
San Francisco
415.627.8410
Alright, are you using the last build Vantage 3.4 ? There are improvements on that regard.
Otherwise maybe we can check this color issue remotely.
I just upgraded… let me play and see if there is any change. And when you say remotely, you mean you jump on my machine?
Since I don’t use the OCIO color mode, I don’t have the option to set the rules. I only use the Gamma 2.2 color mode for all my projects. On a side note, I’m still not getting a wysywig workflow with Vantage anymore. Ever since the OCIO color mode was added to Vantage, I have to constantly add a Vibrance adjustment layer in PS to bring back colors since everything I set in Vanatage doesn’t carry through. I have my color space in Vantage set to sRGB, make my adjustments, looks awesome, then render and adjustments don’t get baked into my .png file. Checked my monitor settings, My color management settings in MAX, Vray and PS.
Looks like two separate issues - Anima people need to be color corrected from the Bitmap node to look right. And I see no reason to not getting the adjustments you have done from the Color Correction tab in the PNG output.
We can try to help you during a short remote session. You can book a time slot via Google Calendar, and we’ll use TeamViewer for remote access. There seems to be a big time difference between us. Just start a ticket from https://support.chaos.com/hc/en-us/requests/new
and we can set this up.
Let me confirm with IT dept to see if this is allowed. Otherwise, maybe a teams meeting or Zoom.
