Why do VDBs take so long to submit to deadline?
Title says it all really… VRay seems to read in the VDB for some reason instead of just throwing a link into the VRScene.
Why is this? and is there any way I can prevent this from happening? It takes forever to submit a scene to deadline.
I have even considered generating an empty VDB for scene submission, then replacing it with the real one with a pre-render script.
you need to read the vdb as packed disk primitive. This way vray will just link to it and not put it in the vrscene file.
Even with packed disk primitives, some operations still take too long, I’ve had that issue before. VRScenes are still small but it takes a lot of time and memory to write them. Last time it had something to do with vray reading bounding boxes, unpacking on the way.
yeah I was reading as a packed disk prim.
Hey all,
It was the case about 6 months ago that indeed, V-Ray was looking up the VDBs before writing the paths to the VRScene. This has been resolved and I can’t reproduce the described behavior on my end. Could you please point me to the build number from the V-Ray → About V-Ray window in Houdini’s top menu bar?
Best regards!
Great, will test that, thanks!
Thanks for the update.
I will double check that I am doing everything right on my end.
As an update, I checked what we were doing here and it turns out we weren’t loading properly as a packed prim. Doing it correctly makes it all work very fast as I would expect!
It used to be the case that VDBs were a bit slow even when using packed prims, but this was greatly improved in the last half year. We had a project last year with lots of VDBs and this was pushed into Chaos for improvement and since then things got a lot better in that sense.
Word of advice if I may, try to deploing studio wide defaults for the File node to already be set to read as packed primitives by default, will save you a lot of issues :wink:
Best,
David.
Good idea. Thanks David.
