Why does VFB keep blacking out randomly?
Ok so I have been experiencing this issue across many projects and even using V-Ray in different CAD applications. The VFB just blacks out and shows the images after some random point. Also, in this particular scene, the colors render washed out. I think this might be a color-space issue because I am trying to avoid using sRGB. How can I render this correctly. The rendering should come out where the unit is dark black with good detail.
Thanks!
Dropbox - Animation_4.c4d - Simplify your life
I apologize for the delayed reply.
The reason for the delayed appearing of your rendering is the light mix and that some of the lights are disabled. Switching the source layer to RGB or enabling all lights in the Light mix will display the render right after the rendering is started.
If you are avoiding sRGB you will also need to disable it in the Project settings (Edit> Project Settings).
