Why image looks good in Photoshop/Bridge and not good in Firefox/Chrome/Thunderbird
I created my image, Post Production I was happy with (viewing/working/saving image in sRGB) and saved the image.
In Adobe Bridge image looks as it looks in Photoshop (good).
But when I view the image anywhere else, including as an email attachment in Thunderbird, in Internet Explorer, in Firefox, Chrome, Windows Explorer, Windows Viewer, the image does not look how I Post-processed it.
Please can someone explain what I need to do to ensure consistency ??
This isn’t about screen calibration - I have two monitors and I can check in both.
Adobe Bridge says images are saved as sRGB…
It’ll be difficult ot know if you’ll be able to see what I’m referring to (on my screen the attached image looks bad because they are both being viewed for me in FireFox), but the image for me on the right, in Photoshop on my screen, looks great (I’m particularly concerned with the wood flooring in the foreground), but on the left (Firefox - the wood flooring looks terrible and unacceptable).
Please can someone help explain what’s going on ?
I need to be confident that what I send my client will be the same as what I see.
Many thanks,
Jez
Check in Photoshop under “View” that “Proof Colors” is unticked
Or press “Ctrl + Y” and see if it looks different
(it should be switched off)
Thanks Morne,
But that’s not it - it stays looking good in Photoshop that way - I did read someplace a long time ago that FireFox does do something with colours etc but I’m seeing it happen in my entire computer, at any place I look (apart from Photoshop and Bridge)…
I just don’t want to send stuff out to clients to view when I have no idea if they’re going to stand any chance of seeing what I see in Photoshop (notwithstanding their own monitor issues).
then in PS check in “Edit” > “Color Settings”
Check in that window that your “Working Spaces” for RGB is set to sRGB IEC
also to the right of that is a button that says “more options”. Click that then the window will expand down to reveal “Advanced Controls” see if both those are switched off:
Desaturate Monitor Colors By
Blend RGB Colors Using Gamma
As for the Firefox things you mentioned about color profiles. That use to be true in the old days, but most newer versions support color profiles and will read the profiles.
In XP and Vista the Windows Picture and Fax viewer did not support it.
Also for a test, from Photoshop, print to a PDF, then open the PDF with Acrobat and see how that looks and let me know…
Hi Morne,
And thanks for your help.
I tried all the settings you mentioned and they are all set as per your thread - so nothing there needed changing in any way.
I have tried to create a print to a PDF, which it does but I don’t know as of yet where it stores that PDF so cannot find it to open (I looked in the settings and there doesn’t seem to be anywhere I can do this) - but I’ll keep looking and get back to you on the PDF side of things once I’ve worked that out.
Many thanks for your help.
Hello JezUK
There are different sRGB standards, and probably Adobe sRGB is different than Windows sRGB - otherwise the image should look the same.
From what I know every windows application use Windows sRGB profile except the software that supports its own color management like Photoshop does.
I guess that if they both use the same profile the result should be the same.
It would be a good idea to forward this request to Adobe Community - the guys there will know better why this is happening and how could be fixed.
