Why is "Connecting HDRI rotation with CoronaSun" a private video ?
I wanted to look at the tutorial on You Tube “Connecting HDRI rotation with CoronaSun”.
But it is set to be private and I can’t see it.
Can this be fixed ?
Cheers Francois
Hi there, can you share a link here for that? I can’t seem to find the one you’ve mentioned.
It’s private because it is outdated and no longer applies with the current versions of Corona. Most likely you were at Learn Corona: official tutorials, free sample scenes & more | Chaos, which still isn’t updated as it is in need of a comprehensive overhaul that will take some time, but if it was from some other location let me know so that it can be removed from there too. Thanks!
Tx Tom,
Yep it was at the location you mentioned.
Thanks for confirming!
