I’m working on an animation, and the camera path travels through a glass door. When I get close to the glass, geometry starts flickering on the other side of the glass. Once I’m through the glass, the flickering stops. Any ideas? I’m using brute force and animation light cache.
Try raising the max transparency levels (Render Settings > V-Ray > Global Switches) and see if that resolves the flicker.
thanks! I’ll give that a try.
