Why is my decal displacment getting clipped?
I am trying to use decals to add some impact crators on a displaced piece of terrain, but for some reason decal displacement is clipped (flat on the top) even in my simple test shown using a radial gradient as a test you can see it being clipped.. the surface its on has 5m displacement and the decal material has 3m displacement .. so i dont know why its being clipped like this?
Seems that your texture has values above 1. Try setting the Texmap min/max to f.e. -10 / 10 on the Plane’s VRayDisplacementMod.
Thank you! will try that
Does ticking the Clamp option in the texmap out not clamp it to 0-1? I dont really see how i can have values over 1 since its an RGB greyscale 8bit bitmap.
im also confused how the displacement offset is calculated.. if i had a decal with a material displace offset value of 1m but the base VrayDisplacementMod is set to 5m amount.. is the decal 1m + 5m so a max of 6m? or is it like a multiplier of the base value?
Yes, the clamp should output values in the 0-1 range.
Regarding the second question: the VRayDisplacementMod has priority over the VRayMtl Displacement (overrides it).
Did you try setting the Texmap min/max as suggested? I’m only guessing what’s happening on your end. Could you attach/send the scene?
displacement_test.zip (76.0 KB)
Sure thing, its attached.
Setting Texmap min/max to -5/5 indeed fixes it. The thing is, the VRayMtl’s displacement Amount kind of acts like a tex multiplier, so when using it together with VRayDisplacementMod, you are obliged to increase the range to get the expected result. I’ve already described this in the mentioned log.
