Why is this happening ?
Hello guys
When i have vgetation nar a wall this happnes…see picture plz.
dont know why.
they are trees convertes from vray…is that the problem? it makes sense to anyone?
regardz
Are you using AO or Round Corner in the wall materials? Or are you using refraction in tree/plant material?
Hello
No AO
Yes Rounded corner ,(see pic)
Fallof in trees materials…
Hi. Rounded corners with radius 1 meter! Thats only gonna make troubles - not round corners. Try turning it off and see what happens. Does the problem persist? If not then try lowering the value to 1cm (0,01m) and turn it back on. What happens now?
Yup, it has to be rounded corners issue.
Looks fascinating, nevertheless :smiley: Could be put to good use in some situation, I bet.
