Just came across this issue and just cant figure out why is the generated foam jumping out of my liquid.
Any idea as to what I may be missing?
Something funky is going on with the falling speed - it’s 1000 cm/sec while your container is just several cm. I’d suggest turning off B2B interaction first, and returning the rising and falling speed to very low numbers, like 1-2. If this helps stabilize the sim, start raising those values that you need to be higher.
Hope this helps, cheers!
