Hey, guys!
I am working on a project, just started. The file has 100mb, some maxtree grass (3 scatters) and some bridge textures.
Some times something changes that the render is not possible because de RAM asked is more than 160Gb. It doenst make sense because i have worked with much bigger archives with more complex objects and textures.
I am using and SSD Samasung T7, dont know if these matters..
Sorry about the english
File size doesn’t really matter - what matters is what you’re doing within that file.
Are you using displacement with too small settings? Or even legacy displacement mode prior to v7 (or v6, sorry can’t remember). Displacement can cause excessive memory usage with very small values.
Are you using render passes/channels? These will allocate the same memory as the main beauty render for each pass. If you don’t need them, try to disable them and see if that helps.
Since the scene is relatively lean, maybe submit a ticket and include the file. I think support will be able to quickly identify the problem.
I turned off displacements and it gots better.
Do you think that “fault tolerant heap” has something with the performance? i dont know what its means
Yes, it definitely can negatively affect the performance. It is advisable to follow the link in the error message and address the issue.
