why the liquid can't be rendered?
hi,my friend is using phoenix fd adv 2200 for max 2016.yesterday he found a problem about this plug-in:he can’t render the liquid created by phoenix fd,only the foam&splash can be renderd.is it a bug?how to solve the problem?[/IMG]
Maybe the render mode in the Rendering panel is not Mesh?
no,he set the render mode Mesh
can you select the simulator and type in the listener $.surflevel ?
yes,i got 1000 in the response.
Yup, so try
$.surflevel = 0.5
Could you just check the About box in the Simulation panel and paste here the Build ID?
:face_with_spiral_eyes:
what does surflevel mean to phoenix fd? why the default value is so high that the liquid can’t be rendered?
a legacy problem, phoenix started as fire/smoke simulator and this value was used to render fires as liquid, it’s considered to be the border temperature of the flame.
