hello guys ,
I have a problem with lights , in the picture with shelves i dont know why the material is glowing even it doesnt have self illumination or anything
and the other picture i have no source of light here but its shinning also
thank you
I deleted the IES light and also the same the problem not from the ies its from the material
@AhmedAkader , that is interesting - it does look overexposed or as if the material is glowing, when it comes to the first picture. On the second I can see that you’ve placed a lot of lights, which would explain why it’s so bright. Is there any chance you could send me the project so that I can have a look at it myself? Beforehand you can also try to reduce the “Exposure” Brightness in the Rendering tab of the Visual Settings. Further, when it comes to the shelf, you may wanna turn down the “Artificial Light Brightness” via the slider you’ll find in Atmosphere tab of the Visual Settings. This should reduce the brightness overall, and make it look less like the material behind is glowing. ![]()
thats it i removed all the lights and it still glowing ,
Also its the same file as this pictures . the other pictures looks realistic but this one its totally different even its the same settings .. I am not sure if the problem from the sun light or what or how to make this floor also look realistic like the other
I have sent you the file in private message
If you don’t have any thickness to your bounding walls then you can sometimes see this (or if you leave off a bit of ceiling by accident).
try putting a “shell” of walls around your interior to block out sunlight on the back faces of your interior walls.
@AhmedAkader you might also want to check & reduce your “Ambient Brightness” setting (Image tab).
@AhmedAkader , I had a look at the project and when it comes to the shelves, it seems that there is indeed some so called light leaking happening, which is why it rendered so brightly. In that case please follow the instructions of both @Gadget_1 and @andybot , as that should resolve it. When it comes to the other renderings I can see that you already got the solution in this thread. ![]()
@Gadget_1 @andybot @Clemens_Musterle
Thank you guys for your help it worked
@Demian_Gutberlet thank you so much for helping and following up ^^
You’re more than welcome - I’m glad that everything was resolvable! ![]()
