why this model does not appear in rendering?
Do you know the reason why this model does not appear in rendering?
(Use VRay 3.0 )
skp file
shark2.zip (76.1 KB)
Explode it to base mesh. It MAY be a scaled component within a scaled component/group that is confusing vray. We have this problem constantly with garbage Rhino models imported into SU
edit: did not / could not download model right not to confirm, just a rando guess
okay.
Maybe, the SketchUp side will not pass V-Ray the correct model scale.
But inside SketchUp, it is the correct view model.
It is a problem which should be supported by the rendering side.
Or you should show warning.
so did that work then? This is a problem with sketchup itself - it gets confused when you have multiple nested groups/components and scales are applied to both parent and child in multiple areas. Just a common thing as there is no reset XFORM command or the like
Having issues like this as well and reported it in the beta forum. Seems to be a bug.
