I’m using here vray sun plus vray cam and vray sky.
Got this results:
and I think the sky should look more like this:
Got this results:
Get out a real camera and test the settings. What you have in the second example is waaaaay too bright of a sky (but is a fairly common color in archiviz renderings)
Read up on the tutorials in the VRay help files about the sun+sky, you can affect the sky colors by changing values. The default out-of-box values of the vray sun and sky may not match up with your particular local.
i d say ur materials look wrong…not the other way around… :?
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17824
This deals exactly with the issue.
It also holds true for newer RCs where the sun/sky and camera ISO have a new model.
Lele
sky
Since there is an issue with the sun/sky cam will having to darken textures still be required or is the issue no that big?
