The two cameras are physically offset in the wold space both at camera and target origin. What would be the reason for this? I am using vray 3 and max 2014.
I might be misreading you, but this sounds like what has happened for a long time when de-selecting the physcamera…(at least pre release 3.)
I don’t recall ever hearing of a fix, but it doesn’t seem to happen much anymore (Still on vers2.x)
It was a real PITA when it happened.
Are there any specific steps that need to be taken in order to replicate this camera behavior?
Do you use a nightly 3.x build?
I think the issue is in the scene which already had an older vray physical camera. If I create a new one in a new scene this issue does not occur.
