WIBU-Key Error 11?
Hi
I have had 1.5 Final installed and running perfectly for 2 weeks (including DR and BB) with no issues. Even DR worked like a charm running as a service. Great work Vlado!
Yesterday after having some network issues my machine now cannot start the vrlserver.exe on the local pc without getting the error “WIBU-KEY Error 11”.
I’m assuming that there can only be one vrlserver running on a network?
As I started typing this I thought I should check by removing the service off the local pc and only leave the one on the remote pc with the 2 USB dongles and voila, V-Ray still works. Strange that it only started to be an issue 2 weeks after installation.
So this is a problem with a solution post :slight_smile:
Cheers
