I’m just wondering if there are some plans on integrate Chaos cosmos in Houdini in the next version of Vray…
Interested in this, too!
There are currently no plans for Cosmos integration.
Really? But Cosmos is a great Vray feature and doesn’t seem to be very complex to implement.
I’m very disappointed.
There seems to be a new trend of not having all features across all platforms…us Maya users arent getting Chaos Scatter tool as things stand. I wonder if these differences will be reflected in the prices? Cosmos in Maya has made some tasks much much faster than they would have been without it, so I would be disappointed as a Houdini user.
Any reasons for this?
Tnx for your insistence, the initial Cosmos support will be added to nightlies very soon.
Ahh, great news!!
Thanks!
It’s already in the nightlies for a few weeks so you could give it a try.
How would that work? When I go to V-Ray-->Import-->Cosmos Browser a window pops up and I get a connection refused error. Not sure if I missed any installation steps.
Well, probably Cosmos service is not installed / running? QAs may help.
Hey @ronald_a ,
I managed to reproduce the “connection refused” problem by removing the Cosmos Browser from the Windows Add/Remove panel. Could you please verify you actually have a “Chaos Cosmos” entry there?
A couple more things that pop to mind:
1. Are you using the installer or the zip builds? The zip builds won’t work right away - the Chaos Cosmos service needs to be installed from the installer itself - you can then safely remove the V-Ray files generated by the installer in case you prefer using the zip builds.
2. Could you please copy the info from the Houdini top menu → V-Ray → About V-Ray so we can test with the exact version that you are using?
Hope that helps!
Hey @Gosho.Genchev ,
we use zip builds so installing the service did the trick. thanks for the pointer!
