Will I ever render this scene? 91pass - 11hours
I used to not really resent the fact that vray can’t render foam without using nasa computers. But I ran into the same problem yesterday, thinking it had been solved a long, long time ago.
And now there is no way to render this scene, because the gpu version looks incomplete and I don’t have access to supercomputers.
The scene is simple - domelight, bruteforce, no secondary gi and a shader in bubble mode without reflex with 0 bounces.
You have to understand the options and use them wisely, Luke! And screenshot them too :wink:
Is this motion blur as well?
Heh. Yeah, moblur is here. I suspect domelight…
So you have GI and moblur and a dome light: it doesn’t get worse than that setup-wise.
How many particles do you have and can you share the particle shader settings?
Will share only if you promise me to render it faster :slight_smile:
Volumetric 0.99 makes things better tho.
Hi. It’s me again. Where can I upload my stuff ? 4gb per frame.
https://vimeo.com/557471047/f68e5329e9
Wow, 4 gigs :open_mouth:
Drop a mail to support and the guys will email you back the FTP credentials :slight_smile:
Thanks!!
Yeah, it is uncompressed :slight_smile:
While me waiting for the ftp, I uploaded several files to a usual place. PMed link.
Yess, just saw it now. Will check it ping you when we know more…
Great! While waiting for gpu foam shading equalization with production - plz look at the moblur dark triangles too!
Btw in today’s nightlies there are a bunch of fixes for the Particle Shader, including the ability to render it in Probabilistic mode (from the atmosphere). This could be a big optimization, so check it out meanwhile…
Hey,
Looks like there are is some issue with the files, there is nothing in the folder. You should have a mail from our support guys :slight_smile:
Ok. Btw - do ya have any tips of cheating with phx shader on gpu, so I get that scattering feeling of foam ? Like in production mode ?
I can’t think of anything except for using really bright color and bumping the bounces to 10.
What a great new version :slight_smile: It is the first time I see such freaky simtime. (version from 31 may - works)
I uploaded the scene. Have fun!
Also, there’s a problem with adaptive grid increase decrease resolution - when grid scales itself
ChaosPhoenix 3ds Max 2022_2.zip (79.5 KB)
Oookay, so the log shows something is slow in the advection. Can you run this same scene on version 4.40?
Increase/decrease resolution seems to work fine here. Are you doing something special? And also, when you install 4.40, is it different?
Hey Paul,
Where have you uploaded the scene? Our support guys can’t find it for some reason. You should have received an invitation for access to a gdrive folder via email.
Just to make sure what the issue is once we receive the scene - it’s slower with the nightly from 1st of June and faster with the build from 31 May? And there is some issue when the adaptive grid expands?
Thanks!
I’m using oldie ftp folder, svetlin I think is ok with this. And scene sim fine with 31 may build (I sim atm with it..). About the adaptive stuff - it is random and close-reopen max helps.
