http://www.pasteall.org/pic/69688
Neither standalone/nor from Blender, all WIn updates installed…I have no idea why I cant make any progress with that…??
Please move the subject to UNRESOLVED BUGS.
you cannot run corona directly, it needs command line parameters. You might probably want to consult the blender exporter manual
Running !run sample.bat OR just running Corona.exe results in windows message: Corona.exe stopped working…
which should not be the case-right?
So neither running from within Blender succedeeds.
what CPU do you have?
Only Corona_legacy.exe test run completes w/out crash.
Operating System System Model
Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
Install Language: English (United States)
System Locale: Polish (Poland)
Installed: 2014-02-12 21:31:56
Boot Mode: BIOS (Secure Boot not supported) No details available
Processor a Main Circuit Board b
3,20 gigahertz AMD Phenom II X4 B55
512 kilobyte primary memory cache
2048 kilobyte secondary memory cache
6144 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Not hyper-threaded Board: ASUSTeK Computer INC. M4A87TD/USB3 Rev 1.xx
Serial Number: 108734260002442
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. 2001 03/08/2011
Drives Memory Modules c,d
1900,39 Gigabytes Usable Hard Drive Capacity
1017,54 Gigabytes Hard Drive Free Space
DUPG X23KD2BWPIB SCSI CdRom Device
PIONEER DVD-RW DVR-219L ATA Device
Generic USB CF Reader USB Device – drive 4
Generic USB MS Reader USB Device – drive 6
Generic USB SD Reader USB Device – drive 3
Generic USB SM Reader USB Device – drive 5
ST31000528AS (1000,20 GB) – drive 0, s/n 5VP5B0RZ, rev CC38, SMART Status: Healthy
ST3400620AS (400,09 GB) – drive 2, s/n 9QG4VRG8, rev 3.AAK, SMART Status: Healthy
WDC WD5000AAKX-001CA0 (500,11 GB) – drive 1, s/n WD-WMAYU3163140, rev 15.01H15, SMART Status: Healthy 16384 Megabytes Usable Installed Memory
Slot ‘DIMM0’ has 4096 MB (serial number 7C09165D)
Slot ‘DIMM1’ has 4096 MB (serial number 7C04165E)
Slot ‘DIMM2’ has 4096 MB (serial number 67820B76)
Slot ‘DIMM3’ has 4096 MB (serial number 67810B76)
Local Drive Volumes
c: (NTFS on drive 0) * 1000,20 GB 617,48 GB free
d: (NTFS on drive 1) 500,11 GB 204,36 GB free
e: (NTFS on drive 2) 400,09 GB 195,70 GB free
DISABLED Marks a disabled account; LOCKED OUT Marks a locked account
Doro PDF Writer on Doro PDF Writer
HP LaserJet 1018 on USB001
Microsoft Shared Fax Driver on SHRFAX:
Microsoft XPS Document Writer on XPSPort:
Controllers Display
ATA Channel 0 (3x)
ATA Channel 1 (3x)
Standard Dual Channel PCI IDE Controller (3x) NVIDIA GeForce GTX 650 Ti BOOST
DELL U2412M (24,0"vis, s/n XX-00FFXD-XXXXX-364-544S, czerwiec 2013)
Bus Adapters Multimedia
ATW5GRXV IDE Controller
HUAWEI Mobile Connect - Bus Enumerate Device
Renesas Electronics USB 3.0 Host Controller
Renesas Electronics USB 3.0 Root Hub
Standard Enhanced PCI to USB Host Controller (3x)
Standard OpenHCD USB Host Controller (4x) Creative SB X-Fi
NVIDIA High Definition Audio
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Virus Protection [Back to Top] Group Policies
COMODO Antivirus
None discovered
Communications Other Devices
Microsoft ISATAP Adapter
↑ Realtek PCIe GBE Family Controller
primary Auto IP Address: 192.168.1.106 / 24
Gateway: 192.168.1.1
Dhcp Server: 192.168.1.1
Physical Address: BC:AE:C5:65:4F:06
Connection Speed: 100 Mbps
Teredo Tunneling Pseudo-Interface
↑ VMware Virtual Ethernet Adapter for VMnet1
IP Address: 192.168.56.1 / 24
Physical Address: 00:50:56:C0:00:01
↑ VMware Virtual Ethernet Adapter for VMnet8
IP Address: 192.168.8.1 / 24
Physical Address: 00:50:56:C0:00:08
Networking Dns Server: 192.168.1.1
BlueSoleil Generic Bluetooth Driver
IVT Bluetooth Audio Bus Driver
IVT Bluetooth COM Bus Driver
IVT Bluetooth HID Bus Driver
IVT Bluetooth PAN Bus Driver
Logitech Driver Interface (4x)
HID-compliant consumer control device (2x)
HID-compliant device (10x)
PenTablet Simulated driver for HID Minidriver
USB Input Device (9x)
HID Keyboard Device
Logitech HID-Compliant Keyboard
HID Tablet
Generic USB Hub
USB Composite Device (3x)
USB Mass Storage Device
USB Root Hub (7x)
Generic volume shadow copy
I:
J:
K:
M:
USB Storage Use in past 30 Days (mouse over last used for details) Hosted Virtual Machines (mouse over name for details)
Last Used
Generic USB CF Reader – drive 4, s/n 920321111113, rev 1.01 2014-04-25 08:03:36
Generic USB MS Reader – drive 6, s/n 920321111113, rev 1.03 2014-04-25 08:03:36
Generic USB SD Reader – drive 3, s/n 920321111113, rev 1.00 2014-04-25 08:03:36
Generic USB SM Reader – drive 5, s/n 920321111113, rev 1.02 2014-04-25 08:03:36
Generic Flash Disk, s/n F9AFB594, rev 8.00 2014-04-22 21:24:07*
Generic Flash Disk, s/n 425875DF, rev 8.07 2014-04-17 12:57:27*
USB DISK 2.0, s/n 07AB0F0890704765, rev PMAP 2014-04-15 07:02:45*
OCZ RALLY2, s/n AA04012700359966, rev 1100 2014-04-11 08:11:47*
WILKELEK GOODDRIVE, s/n 07A20808B32DBDD9, rev PMAP 2014-03-29 19:54:14*
ok, you just need to use legacy version of corona. I’ll make legacy standalone build soon
itd be awsome, for me a min. req. is to render from within Blender Win 64, just let know when available (on Blender Artists also pls)
