So i got problem with the wall..
the wall must white in color but has a crack effects that i edited in sketch-up…
the problem is when i render i turns to grey … and the crack image i use is color grey. but i set it to color white.. but why it still grey?
2nd problem.. i put a floating wall + image background on the front of my building but the problem is it wont show on my windows
Re: [WIndow BG and SU wall detail] need help..with pic
i use old 1.48.89 the gray crack image is the original .. and i want to color it with white.. i just edit the balance of the crack using the sketch-up resize as you can see below the use texture thing.. its 2X2 Mts. but and i set it to color white .but in v-ray after render its still thesame gray original image not white. y?
