HI Everybody,
I did search all over how to make the glass material on windows realistic. For some reasons it looks very dull.
I used Reflection and Refraction with default settings. It looks so far the best but the reflections are not even close to realistic window glass reflections.
Any tips?
An example of the results you are getting, plus a screen grab of the material, and some information about how you set up the scene (environment lighting, what is in the scene for them to refract/reflect etc) would be essential for anyone to be able to advise on potential ways of improving things ![]()
You can’t see reflections on windows, because outside is brighter than inside and because of that, reflections are simply overpowered by refractions. You have two options, either place some dark surface behind the window or fake material by setting its fresnel IOR at much higher value, but be aware, that it will look fake, because… it is fake :]
Plus:
Your basic problem with the reflections is: There is nothing to be reflected!
Using an HDRI with some would be a first step. Trees and buildings outside also help.
HDRI and trees won’t help here - things that are outside, cannot reflect on inside ;]
I thought his issue were the boringly empty windows, but I might be wrong.
Hmmmm… I would say that there’s plenty of reflection in the windows. Actually everything in the room is reflected. So what am I missing?
Thanks forlks, ill try some of those. I know HDRI is good but as i need the reflections inside. If this would be a real room. THe window openings would also be reflected from one window to other. I guess ![]()
What are you expecting? Do you have a photo reference?
Because I can’t see anything in your image that looks off when you look at the glass. It reflects all that should be reflecting in your room right now.
Difficult to explain but still in my mind the glass settings are not enough. I have seen many empty rooms
with glass windows that is the only reference i got. I might be wrong.
**Found the missing part
| its all about the volumetrics settings. Just needed a bit of more reading “manuals” who needs them ![]()
