I am using hdri map to light the scene. What’s the best option to get desired reflections to windows in one pass render? Glass materials override slot does not override totally hdri reflections. It’s a bit mixed result. If I use plane with desired background every reflective material reflects it. I would like to just windows reflect the background on the plane. So what would be the best option?
It’s hard to tell without seeing the scene, but probably what you see is refraction. You can use refraction override or disable refraction altogether for your glass, whatever works in your situation.
It was refraction that caused the mix. It’s abit pain to use jpeg in override slot cause it’s really hard to adjust the right part of the image to reflection.
I like to use lightmaterial on plane and put my bg image there so window reflection catches that plane. Is there any to to tell corona that the image on plane should only be reflected by windows and not affect any other material or object?
