Windows 10 upgrade
I only have it on my personal laptop so far, not brave enough to upgrade my workstation yet (it has pro as well).
I definitely wouldn’t upgrade in the middle of anything…definitely do it when you know you will have a day or two of downtime to work out any kinks that may arise. It’s common sense type stuff, but some people jump in head first! LOL
I tried the upgrade path on some of my render slaves. Cannot get VRSpawner or VR RT Render Server to register and start as services. Could manually launch VRSpawner on the slave machine, after which the slave participated fine in the distributed rendering task.
So for now, I’m going to reformat new and restore the slaves to Win-7-64 until things are more stable.
Edit: Right click the menu item to register the VRSpawner, select run as administrator, and it registers correctly. No problems after that with DR on the farm. Can it be that Win10 is a bit faster, or is it my imagination?
‘If you are not paying for it, you’re not the customer; you’re the product being sold’
just a thought…
hm.. i didnt realise windows 10 was going in that direction… seems like a solid reason to stick with win7.
Overblown, in my view. When you install 10 it allows you to customise the installation, which of course you must always do. It then comes up with a long series of questions allowing you to turn off anything you’re not happy with, including anything that would send info back to MS. Turn them all off and you’re back in the same seat as you were with 8, 7, vista, XP or whatever.
Win 10 is supposed to bring significant benefits for multimonitor users (which I’d guess is most of us working in graphics), apart from smaller memory overhead, faster boots and other benefits, not to mention it’s free (that’s many hundreds of pounds saved for me) so as far as I’m concerned this is kind of a no-brainer. I will be rolling it out once it’s been through a few rounds of updates to squash any obvious bugs, and once all the main packages and plugins fully support it. I’m guessing 6 months or so.
I’ve bee on Windows 10 for a month, quite like it, much better than Windows 8 and works much better on my UHD monitor than 7 ever will. 3dsmax 2014-2016 work fine. Vray 3 works fine but I did need to download and install the latest WIBU drivers to make my dongle work.
Yeah, most stories about Windows 10 have been blown WAY out of proportion and/or clearly not understood by the person writing the story. If you are willing to take the time and customize Windows 10, it will behave almost like windows 7, only better! :wink:
I did a LOT of custom settings in Win7 to get it to work the way I wanted it too!
I agree 100% Simon…welcome to the world of Microsoft selling all your personal details on to other companies
IMHO Marketing is getting seriously out of hand, most TV shows that i watch on cable lately have equal and what seems like less air time than the commercials that are running on them, I’m dreading the day Netflix or Apple TV shows start letting commercials on their platform. Also lately websites, it seems like almost every site I go to lately you have to click through 2 to 4 popups ranging everything from Today’s Specials, chat with our staff, take our survey… and now with what sounds like Winblows10 sending advertising to the desktop and other apps Ill gladly pay what ever if possible to keep from being bombarded by ads. Ive worked in marketing for over 20 years now and although I like the work I hate that in today’s society that we are bombarded by ads absolutely everywhere…
*sry about the rant* :stuck_out_tongue:
Just installed Windows 10 and having some issues with licensing. I can render using normal V-Ray fine either locally or using DR or backburner. But when I try and render using RT it comes up saying could not initialize renderer (no license)? If I switch back to standard renderer I then get could not obtain a license (-98). If I try and terminate the V-Ray license and reload nothing loads and then after about 30 seconds I get a WibuKey error. One of the following licenses are required: xxx Failed reason: WibuKey API error occurred (Error 18)!
I must reboot to get the license working again.
I wondered if this is the issue you experienced?
Thanks!
OK everything working now which is a bit random as it didn’t work the first 10 times I tried it. I will keep an eye and see if the issue comes up again.
@jamescutler: I don’t know if you have done this yet or not, but I believe you will need updated WIBU drivers for the dongle for windows 10. I believe that is what I needed to do…but it’s been a few months now and I don’t remember exactly. But check it out just to be safe.
The latest WIBU driver appears to have done the trick, thanks. The issue occurred a few times after I last posted but since the update, so far so good. Certainly worth doing if considering to update to Windows 10.
That’s great! Glad you got it sorted.
I just “upgraded” a machine at the office to see what kind of issues I can expect on a machine that has been upgraded instead of installed from scratch.
I just did an “upgrade” as well on a laptop I don’t care about to see how it performed. It was a win7 machine. I ran it as a slave and found backburner runs fine and vray works fine. I can’t find any issues so far. Other than sitting down and turning off all of the settings that send information out (which are basically the same as win8 as far as I can tell) it’s no chore at all. Win10 installed easily and quickly.
I am going to wait a bit to install it on other machines but so far so good.
After a week I have had a few issues.
1) V-Ray license would stop working mid rendering animation. Turns out the WIBU key was at fault. A simple WIBU key driver update solved the issue.
2) Desktop wallpaper keeps disappearing and going black when minimizing apps. Not sure on this one as I put it back to what is was before and its fine but I have done this 5 or 6 times now.
3) the MultiTexture plugin will not work on the render node. If its in the plugins folder, backburner server wont render and says there’s an error loading the DLL. Even if MultiTexture is not used in the scene. MultiTexture works fine on other workstations though. Go figure.
4) I occasionally get pop ups saying I don’t have permission when editing files, so there must be a new level of security I need to sort out. Didn’t happen in Windows 7.
5) Windows added a monitor profile which causes Photoshop to not display correct colours. I normally remove this profile so the monitor matches V-Ray. This works as expected but for some reason in Windows 10, without the monitor profile, PNG’s display very bright in picture viewer, unless I go full screen and they look correct.
6) Not really an issue but in order for Cortana to work, all your language packs must be set to the same one. Took a while to figure that out. Now I can open 3ds Max without a click. Shame it cant do my work for me.
7) The render node got stuck on install, setting up the desktop. It said this is taking longer than expected but should be done soon. After 24 hours I restarted and I was presented with a half installed OS. I had to download the ISO and install it that way. It was done in 15 minutes as was all the other computers I installed it on.
Other than that its alright…
No issues here, however I am just running one machine. Well, I guess I had one issue. One of my PS plugins had to be re-activated.
Depending on the activation method used by the software, re-activation may be needed for them. Just as FYI.
hmmm given the reviews here, which I trust far more than anything else as you all are writing on real world experience I might give it a shot on my laptop, just got notification last night my update was ready…
