hallo at all,
has anybody experience with V-Ray and windows-vista 32bit? Does it run well?
thanks
hallo at all,
thanks
Re: windows vista and v-ray
Yes I have it installed and it works fine. There are several things that you should be aware of.
1. All installs (Rhino and V-Ray) need to be run with admin privledges
2. For you best vista experience use SR1
3. Its best to change the compatibility mode of Rhino to XP
4. At least the first time you run Rhino after the V-Ray install you will need to run that with Admin privledges as well.
Running as an admin is easy. Just right click and select run as admin. Compatibility mode can be set by right clicking on the rhino logo and going to properties. There should be a compatibility tab there.
