WINDOWS VISTA X64 BITS Not working
Before anything pardon for my bad English, the problem I have is that I can not install vray on windows Vista 64-bit, it gives me an error message when the program started, as I have to do? Not in 32-bit gives me problems and I use the same process, please need help.
Re: WINDOWS VISTA X64 BITS Not working
Nobody knows whether or not it can be installed on 64-bit and because it gives trouble doing in the same way that 32-bit?
It says.
Error Loading File VRayForSketchup.rb
126: The specified module could not be found. - C:/Program Files (x86)/SketchUp 6/Plugins/VRayForSketchUp/VRayForSketchUp.so
I believe x64 systems will actually have two program files directories: one that is either just program files or with (x86)m and another which is program files (x64). Make sure that the SU installation and the Vray installation are in the same folder. If they are not, then vray won’t run
If that is what I do, install vray and sketchup in the same folder x86 but even so I still give that error or I put the screen in black, but that was not done, I have tried every possible way.
If anyone has suffered the same thing that I, I would like to tell me how you do that because I need to know how install.Thanks.
We’ve had a number of people have issues with installing on vista. I believe I have gotten mine to work, but thats 32bit not 64. Remember that vista has a lot of “security” blocks to prevent program access to a number of things. One of those things is the registry, so make sure that during installation, and the next time you start SU that you have specifically allowed admin rights for those processes. Beyond that, I’m not sure what else it could be…If that doesn’t work, then i’ll have to go digging around.
