Hi at all!
this is my latest personal project rendered with corona, standard setting and post-pro in Photoshop.
comments & critics are welcome.
very nice, the only thing is that on the close up at the chair, the roughness map seems a little low res. Either the pattern of the map is weird making it look like lowres or it is lowres, dunno.. But still very cool renders ![]()
Looks great - a making of would be great ![]()
Loving the mood! The white lamp on the 4th image could use a bit more circular subdivisons. May I ask where did you get/buy the wooden planks texture?
Thanks!
Hi…Very nice renders…i like wooden flooring most. is it possible for you to share flooring material setup?
Thank you in advance.
thank you very much for all the comments,
yes you are right, it’s not a good model… wooden planks by cgsource.
wow, so realistic! these results are amazing
