Winter
Winter.
Cinema 4D + Corona A6
lovely mood!
mind telling how did you approach snow on trees?
Snows on the trees are part of the model right?
I like the image by the way…
Hmmmmm I’m having a hard time reconciling that the sky you added in post doesn’t match the lighting in the scene
I have duplicated the polygons of the pine needles and positioned an centimeter above. Then I added a snow material with a displacement map. The texture is an long oval with soft edge, so it looks like as if a heap of snow is on the needles. This looks good however only from far away well out (like the forest behind) :wink:
The HDRI was properly positioned. The sun in the HDRI stood exactly at this point. I have later aligned the backplate picture on this position.
It all could be fixed with postprocesing ) if you guys don’t mind.
Nice..
this render remind me this free scene by vizpark (not the same of course)
Hmm, i’m not sure about that. Your colours are better, but contrast is too much.
May be. I belive that there could be much more pulled out of VFB.
