WinXP 64-bit Network hangs
Running XP-64 bit with mix Win2k and Win3k servers. For the most part
no issues but my machine but locks/seizes in what appears to be a
random way but frequently, every 1-5 minutes. The autosave is 20 mins, it is a Dual Opteron 280, 6GB RAM and Nvidia 4500 512Mb.
The CPU and RAM do not show as being underload when this occurs, looks
mostly like network access of some sort. This does not appear to occur
when I am working locally.
The others in my room are XPsp2 and Win2k, no reported issues.
There is one other machine in the shop that is single dua core, 2GB ram
and experiences the same probem.
Been probing MS site and others with no success, anyone got a tip or two?
It might be a virus that’s hitting your box from somewhere else. I have not seen this (I’m on XP64). I did have this problem once on regular XP… finally turned out to be a processor overheating because the fan was failing in an undetectable way.
just to be sure its not a funky CPU issue, make sure you ahve the AMD driver installed.
http://www.amd.com/us-en/assets/content\_type/utilities/amdcpu64.exe
Also make sure you ahve the absolute latest motherboard and onboard NIC drivers installed.
And it definitly only happens when using max on a network file?
I’d like to point out that that driver is for Athlon 64 chips, not Opterons.
*** Edit ****
Hmmmm… apparently AMD’s site says its for Opterons, even though the installer says “Athlon 64 Processor Driver”
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30\_182\_871\_9033,00.html
Have you checked your event log? You might find some suspicious entries prior to each system freeze… if so, I have had a similar problem.
Unfortunately I’ve not found a solution. In my case, the problem seems to occur due to having local drives mapped as network drives.
Maybe you have the same problem… maybe not,
I would like to point out that i know “exactly” what im doing :smile:
mmmmhmmmm… sure you do
True Story :wink:
Thanks guys, trying a few things, looks like it happens outside of MAX as well. Checking trying things now. Tried some things Juju had posted did not work though, not running NetBios and have host files updated.
It is weird, and annoying.
A complete system freeze? I don’t think that’s network related. If it is a complete freeze, then it sounds like a memory issue. Ren memcheck or the memory tester from the Microsoft website:
http://oca.microsoft.com/en/windiag.asp
i can recommend memtest86 plus
open source, comes as boot images or executable files for your usb stick
a dos-based tool is better since you cant scan parts of the memory that are currently in use
damn, thats what i get for re-submitting a post when a php error shows up - thought it was a server issue :sweat_smile:
Failed sending email :: PHP ::
DEBUG MODE
Line : 234
File : emailer.php
yeah trully anoyng!
same problem here with xp 64 and 4gb of ram when memory-remapping is enabled in the bios (dfi nf4 ultra-d), else there are only 3,5gb available).
network-connects hanging with max, but explorer and other stuff works.
when disabling memory remapping averything is fine (exept the missing 0.5gb)
any ideas on this? newest bios, newest drivers in use …
just to put my 2cents in, is this a problem with UNC paths?
