Hi guys,
this is my practise room after moving from 1.09 to 1.46, its a wip so will add more stuff soon, any 1.46 hints and tips always appreciated.
Cheers
TD
Hi guys,
Cheers
TD
Pretty high rendertime there Ted.
If you want to post your settings up I can have a look and see how to reduce that time.
Nice clean render tdarcy. However, the scene perspective looks off - the chair’s big and the room looks tight. Good call jacksc02 on the rendertimes - wondering what setting is doing that.
uuusually its due to QMC used for secondary bounces will have the setting of 50 when transfering a scene from 1.09 to 1.46 glossy settings as well could be higher than needed
Thanks for the replies guys
I did optimise the scene for 1.46 most of the settings are similar to the flipside tutorial scene. There are some glossy reflections in there and also some displacement and when I rendered this image I had set the imap settings to high, maybe this is why the time seems slow. I thought the time wasn’t tooo bad because it was rendered on a pentium mobile laptop with 2 gig of ram. I’ll go and tweak some more ![]()
Cheers
TD
