… once again another car park poroject which gets renovated and redesigned from ground up. I am only showing a small part of this extensive work here for the time being.
Note on the artificial lighting:
Only 2 lighting components are used.
- a linear luminaire component which is distributed at least a 100 times so far on the ceilings. This is designed as a visible light source with a self-illuminating material, but the light itself is provided by an Enscape emitter surface that floats underneath and
- a self “wall-cutting” light component (the same principle as for windows) for the indirect floor lighting in the area of the driving ramps. These lightsources are each equipped with 2 Enscape linear light emitters.
[SketchUp 2021 / Enscape / Photoshop]
