WIP exterior Image
I wonder if anyone can suggest a method to fix the repetitive brick pattern as highlighted on the image.
Any other comments to improve the image would be welcome.
if it’s a bitmap image you’re using for your bricks, get a new one that’s several times larger (more bricks). That way the repeat pattern will happen farther apart and be less noticeable. If you’re using the brick material - it’s an easy fix. Change your mapping coordinates to be double or triple what the are now, and then increase the number of bricks by the same number. I usually try and get at least 20 bricks across before the repeat happens.
hope that helps.
Mattman
another method i find usefull for large bricks areas is using a blend material that consists of 3 brick materials with different hues and seeds. the blend map is noise with the right scale for your distance and scale of the camera…
hope that helps
p.s. your cars looks very realistic - i’m wondering if it’s a well rendered 3D model with good reflactions and materials or a very well combined image/rpc. in any case - the cars looks much more realistic than the buildings…
hi.
for great brick textures, try http://www.boralbricks.com
although the site seems to bee down at the moment :?
also i think the shadows under the cars are too dark compared to elsewhere in the image…
or here, brick texture maker stuff (really great!)
http://www.accurate-image.com/acme/help/
yeah… that’s the same as the boral brick thing…
highly recommended.
where did you find the images of people? the blonde is very cute!!
I think the cars don’t match the lighting of the scene.
