Hi All,
I am workign on a render for a colleague and am looking for some advice. Attached are my most recent render, SUP screen shot and an image of the outlet itsef (it has already been built). As you can see I am having some problems with the lighting and reflection in the changing room (far corner) and the lighiting in the light boxes on the left hand wall. Render time took 40 minutes and I have made some adjustments in PS to make it a bit more realistic. Any advice on how I can make it more realistic and fix the problems i am having?
Re: WIP Help Required (Interior Render Retail outlet)
Hi Rob,
Your render is very close to the real thing. Good work.
Few little things I’ve noticed are the bad lightning in the far corner, looks like the illumination isn’t subdivided enough. Also the marble’s texture is noticeably repeating. I would add reflection to the purple table/bar.
Thanks for the coments. Glad you like the renders. Yes I am still working on this. Just wanted to post to get some ideas on how to improve. I’ve added some more omni lights but I still appear to be getting some spotchiness if you look at the reclections in the mirrors. Any suggestions an how to improve overall apearance?
