My 3D:
Foto:
looks great! I think the water in the first shot is the only thing that looks like it could use some more work.
Might be nice to have a few leaves bunched up inside the column area, in the corners maybe? The leaves in the bottom photo blend in much better than the leaves in your renders, they stand out a bit to much in your renders.
Water:
You still got it, nice work. Just sun and sky or some new method? ![]()
:shock: beautiful
awesome :shock:
Welcome back master saluto 8)
Great work, as always. Congrats
bye
Neo
Nice work!..
Wow! very convincing.
this is definately one of the nicest pieces ive seen in a while
saluto, any chance you could re-upload your 2 images? the links are boken
I salute you Saluto
Fantastic work
Tom
I am simply amazed what can be done now…Great work my friend
wow…I couldnt believe first one was a render!
good work.
ah, I guess the water is pretty close then. I’d say a little bit of blurring in photoshop on the water, it looks alot more crisp than the water in the reference image, soften it up a bit and I think it would be there ![]()
The water line on the concrete, yours looks like a noise pattern, I think that could be a little bit crisper, more like the shapes of the reference instead of a general noise/pattern?
:shock: WOW
Stunning renders!!
wow, what an amazing render!
how did you achieve those shadows? is that actual geometry casting shadows, or some kind of mapping? or both?
it’s amazing how such a small touch as leaves on the ground can add so much to a render, great work, really impressive!
:shock: , the photo looks like a bad render against your images!
nice job very convincing
-dave
