WIP Interior Stairs
http://www.resolutiondigital.co.uk/Vray/stair01.jpg
Comment welcome.
way too much perspective going on.
also the ambient lighting seems as bright as the sun or brighter.
http://www.resolutiondigital.co.uk/Vray/stair02.jpg
Thanks for the comments. Sometimes you work on a project for to long and you get side tracked. I have switched of the lights and just using the sun to light the scene, looks much better and i chnaged the lens to reduce the perspective.
Much better. If you want, you can leave the lights on, but keep their intensities in a real world scale, and there should be no problem. The main benefit from a “physically correct” render engine, is that you can simply put in a 50W bulb, and it will have a correct intensity compared to, let’s say, the sun.
A.
This is indeed looking alot better then the first one. I was getting sick when I looked at it because of the perspective :wink:
The only thing I’ve noticed are the wide grooves between the tiles in the floor. I wouldn’t let a small child walk on that floor in fear of having their toes getting stuck…
